Hi There.
We have an 1800 century granite cottage in Cornwall which we are renovating or at least were until the Council said we need a bat survey and told us not to do any more renovations, but thats a different story !
We have a line of damp where the floor meets the solid walls. We are laying 60mm of insulting lime render on the interior walls and I am thinking of putting a mesh fillet in the corner so the damp is not in direct contact with the lime as I think the lime will keep drawing the moisture out due to capillary action. If there is an air gap then this will not happen to the same extend.
The wall that this concerns is situated close to the spring that supplies the water to the property so I can see the water level in the well and at the moment it’s quite high. This only concerns the oldest part of the building as the new section has a full DPC. All the floor levels are at good 200mm above ground level.
My concern is that if I just plaster straight into the corner the lime will just keep drawing the moisture through the wall due to the high water table. The previous owners had tanked the area to about a metre and gypsum plastered over it but this had failed so the plaster was blistered and crumbling.
Does anyone have any advice on this course of action or alternative ?
Thanks in advance.
Thanks in advance.
