Hello all
We've not long moved into a Victorian semi, a lovely place indeed.
We had a building survey done prior to purchase, and the surveyor recommended rebuilding the chimneys in order to insert a lead sheet, to prevent damp. There are obvious signs of damp in all three rooms on the top floor which the chimneys pass through, some more than others.
That was the recommendation, but as a bare minimum he reckoned we need to repoint the top of the chimneys.
There are three chimneys, two on the eaves and one at the back thats a bit more difficult to get at. But everyone that's looked has said scaffolding access is good.
Obviously rebuilding is going to be/would be pretty expensive. The more I look at them I think they look ok apart from the very top, and that water ingress is likely from cracked flaunchings, so rebuilding the top part could be a reasonable move.
I'd be interested in any advice you can give about what I can look for to indicate whether I do or don't need to rebuild.
Currently one chimney has an open fire which we would like to put a woodburner in, the rear chimney has an open flue boiler running up it and there is a gas fire in another chimney - so we could I hope keep a bit of heat in them over the winter, and that this might help a bit.
Some pictures; they are not very good I'm afraid as they've come from the first viewing. But you can see the general condition I hope:
rear chimney
rear side chimney
front side chimney, algae
rear chimney
rear side chimney
