Hello,
I've been browsing the forum for a while, absorbing all your tips, but now I need some advice and I hope you can help.
We bought a cottage (approx. 1780s with a weird 1989 flat roof extension) that has some sereious issues with penetrating damp due to general poor upkeep and modern non-breathable paint on the outside. We've removed the exterior paint and set about getting plans and permissions in place to make some changes to make the layout work better for a young family and to install oil central heating (currently it's only electric storage heaters and unfortunately renewable systems are not suitable).
Because of the damp the plaster is completely shot and needs replacing. Now our architect tells us that building control will insist that we put in 100mm celotex insulation. Aside from the impact on space, I have serious concerns about the suitability of this for an old property with a history of damp. Is there anything we can do?
We've also been told that the floor needs to be completely replaced with concrete. Here's what our architect said when I questioned that:
"Unfortunately, the existing floor is made up of 2 layers of tiles on ballast and not much else. When all the other elements of the house are upgraded and the heating is switched on, the floor will draw up a lot of moisture. Just because it hasn’t leaked yet does not mean to say it won’t leak in the future. Also your heating system will need to be designed with a higher load to take into account there is no insulation in the floor. This means the radiators will have to be bigger. I have confirmed with building control if you leave the floor exactly as it is then you may not need to upgrade it in terms of insulation. You would not be able to take the tiles off. You would need to apply some sort of waterproof membrane and put a floor finish over that. We would strongly recommend you replace the existing floor in order to prevent further costly repair works in the future."
I'm concerned that a concrete floor is also inappropriate for a property like this, and any sort of waterproof membrane might exacerbate damp problems, as previous modern 'solutions' did. Are my concerns well-founded? I have a couple of photos of the floor which I'll upload separately.
Any help would be greatly appreciated, I feel like we're being railroaded by our architect and I don't have the expertise to make the right decisions.
