Yep damp discussion again.
We have had a damp problem in a 22inch stone wall, and l have fixed the initial water problems problems - l hope
The wall is a 22inch stone that is lined inside with lath and plaster, and there is a cavity between the stone and lath.
The issue is that the chimney and wall have been soaked for a number of years and it will take a few years to get the stone wall back to its original dryness. However part of the wall in the dining room has stained onto the lath & plaster this includes a brown stain from the chimney, which keeps leaching through the decoration. I am confident that there is a draft at the back of the lath and plaster and that there is airflow from the under floor area to the loft.
I am now thinking of using damp proof foil on the wall to hold back the stains, Not on all of the wall just the section between the ceiling and picture rail. My thoughts are that the walls will still breath and that drying will continue, and that the foil will then hold back the staining which has made its way through stain block already.
Am l missing any other trick or issue?
