My house is an 1950’s, stone built cottage with a cellar.
The cellar has been tanked (Not very well) at some point and has an air brick in one corner just above the outside ground level, a radiator, a door separating it from the rest of the house and a variable speed axial fan fitted by a previous owner extracting air into a riser pipe on the outside of the building (he made models and I assume the fan was for fume extraction)
The cellar is always damp, anything I put down there becomes either rusty or mouldy or both. Hygrometer readings generally show 100% RH.
This dampness is the case all year round, even during the 2 month heatwave we’ve just enjoyed.
I’ve tried a variety of things to correct the situation such as turning on the fan (no change even after days of running), opening/closing the door (nothing)
The only thing which seems to dry things out is turning on the radiator which I generally only do in winter.
The dampness is particularly concentrated near to the air brick, the ceiling timbers there are always damp and mouldy and none of the others are.
Can anybody suggest what might be the cause of the problem?
Would blocking up the air brick help?
Thanks,
Sploing
Thanks,
Sploing
