My 1870's end terrace is built into a hillside and the back wall and some of the gable end wall in the livingroom are completely under ground. At the base of the corner where these two walls meet (roughly north facing) I get damp, to about 40cm high, about 60cm wide. it looks like surface moisture when it is damp, and i am assuming that this area is very cold (perhaps caused by moisture penetrating the retaining whinestone wall behind?) and the damp is perhaps mainly condenation, though there is a faint tidemark and no mould. there appears to be a cavity between the whin wall and a brick wall, which has been plastered. Below the suspended floor the joists are fine, though the ground below the floor at this corner feels damp and cold to touch. I am in the process of redecorating, with fingers crossed decor wont get too trashed too quickly. House was renovated in the sixties and I think there may be some concrete on the ground as well as some use of tar - dont really want to have to dig that up as very dry apart from the one corner. have lifted carpet and laminate and am going to sand floors, which should also help ventilate underground space. Question is:
If the decor gets damaged, or I get problems with rot in the joists, could i strip back the plaster from the brick to about 1m high on the walls affected, and have it replastered with lime and repaint with limewash? Or should I replaster the full height of the walls in lime plaster?
I guess that moisture is being pushed up the walls due to the concrete floors and I assume that lime plaster will allow any moisture in the bricks to evaporate naturally: I was given a quote for tanking to 1m but as I gather that this will just displace moisture, I am not going down that route.
