TimHardusty
- Portland, Dorset
Our 17th century Portland stone cottage has a sloping-roofed single storey extension at the rear (probably 19th century) that we want to turn into a downstairs loo/shower room.
The rear wall suffers a little damp (no damp proof course), and the side wall has a damp problem that is probably a leak in the roof structure that I will fix.
In the rest of the house, we are very conscious that allowing the walls to breath has made a great difference to the dampness compared to when we moved in (vinyl paper, gypsum plaster, etc.), and if we were keeping the space at the rear as "generic" living space we'd do the same.
But, as a loo/shower room we will need to at least part tile it.
Long introduction to a (hopefully) simple question: if a wall has no damp proof course (or foundations to speak of), is made of limestone, and - ideally, I assume - needs to breath, what actually happens if you fully tile it?
Do the tiles drop off after a few years? Does the water rise all the way up and rot the roof?
I have considered battening the wall and lining it with a board of some type...but does the water then condense, run down, and seep under the (screeded) floor?
Am I over analysing this!!??
Help!!
Help!!
