(repost from greenbuildingforum)
I have a wall that is causing me much head scratching - any wisdom is appreciated. I also guess a picture tells a thousand words so there's a crude plan and a photo here :
http://s712.photobucket.com/albums/ww123/snyggapa/
The problem we have is with the party wall, pictured (centred on one of the chimney breasts) . It's 200+ years old, single skin brick , no DPC. Apparently it has a "damp problem" - neighbour has apparently had it drilled and injected 25 years ago, but that is now failing (or the waterproof cement they added to cover the failure has now failed) - either way, they apparently have damp against that wall in their property and there is no obvious internal source of the water.
To be fair, the wall kind of "looks" damp although some of that tide mark visible is from where the soil under the now removed rotten wooden floor has been excavated away. We have removed the coating from the wall - it used to be lime rendered , with a nice cement render and plaster on top, which I guess trapped the damp in nicely - and I would guess that the now exposed wall is now drying out quite effectively. The problem I have is what to do with it..
Unfortunately we can't just leave it exposed which would be my personal preference - it's so thin that you can hear everything next door - and the place is so small that you can't get away from the noise, so we need some sound proofing and if it comes with thermal insulation, all the better.
I am assuming that the damp is being drawn up from the ground - we're on a drained fen so have a high water table - and I have 2 choices , either to stop it rising by putting in place a DPC of some kind, or let it evaporate as originally intended.
We are hoping to be allowed to put back a suspended timber floor however this need to be agreed with the BCO since it violates pretty much every current rule regarding timber (flood plain, high outside ground levels) but if we could do that then it should be possible to leave the bottom 9" or so of the wall below the finished floor open in the ventillated void - is that likely sufficient to evaporate off the rising water, or would the damp typically rise to higher than this? Are there any ways of giving a helping hand by for example lime rendering the bottom 9" of the wall to increase the evaporation area, or would that likely just wick more moisure out of the ground?
If the damp is likely to rise above the floor then i'd need either a void between the wall and the soundproofing/insulation, or some kind of soundproofing/insulation that actively lets the water out of the wall. Does anyone have any ideas or better suggestions..
The domesday scenario which our plans agent is working towards is the installation of a concrete floor to current building regs standard - he recons this is all that BCO will approve - however I can only see this making the damp worse by trapping & forcing it it to the wall and giving it nowhere to evaporate to.
Does anyone have any suggestions how to approach this?
-Steve
-Steve
