Hi, I’m a new member so forgive me if this is going over old ground! We have just bought our first property, a modest 1870s terrace in need of complete modernisation. We are on a budget which stretches to diy only! So, if anyone out there has a solution to our problems, it would be great if you could include product recommendations and/or or a blow-by-blow account of how to tackle the job.
Ok, the situation is that our ground floor is damp. I was going down the route of DPC and concrete flooring to include DP membrane but then someone suggested I check out this site first. Having read some of the previous discussions on the subject, I can see that my plans are likely to attract …. er ‘negative feedback’ I’m all ears when it comes to alternatives as many suggested solutions seem also to be cheaper and less work which is fine by me!
The existing floors are mainly quarry tile directly on sand. The hallways have about 1 inch of cement. It’s all damp and I don’t mean the surveyors damp metre says so type of damp – noticeable wet patches on all floors. Plaster was falling off, the skirting was totally rotten and the bottom of the doorframes and stairs are going the same way. DPC has already been done and to be fair has dried out the walls. We are now looking for a way forward with the floors. We have been here for a few months now (living upstairs) and, unfortunately, I don’t think that it’s just going to dry out or that it is moderate enough to live with. We have checked for causes such as outside ground levels being above floor levels and dug down to check for leaks on a couple of the worst areas but found nothing. Any ideas? Or will it have to be concrete after all?
Once the floors are sorted, all remaining ground floor joinery is suffering from some sponginess / rot at the base for a couple of inches (has been checked – no dry rot thankfully!). Does anyone know if it’s possible to treat and/or fill the existing doorframes and bottom couple of stairs, or is it a rip them out and start from scratch job? I’m assuming this is a complicated and expensive job best avoided if at all possible?
If anyone managed to get through all that and is still awake, well done and thanks for reading! Any advice will be massively appreciated.
