We have an early Georgian wing attached to our timber framed cottage including cellar - and these have been bugging me since we moved in! Approximately mid-way up the walls in the cellar, there are these Gothic style recesses - 4 in total, but not on the rear wall or wall where the original external entrance is. Access to the cellar has changed over the years, looks like a horse(s)/animal was kept at one stage and the external original entrance is wider than a necessary door width. We also have filled in stairs which would lead internally to the older part of the house and also the start of Georgian stairs (brick steps with wooden surround) on the left hand side wall - but unsure if these went into the room adjacent above (later Georgian addition) or just to the outside world as when originally built the left side of the building was external.
These cubby holes have a smoothed base surface (limecrete I think) and interestingly the top courses of brick on the rear do not go all the way to the top exposing the soil behind just beneath the point of the arch.
We have thought candle lighting, although there is no noticeable blackening. Poking around behind two holes recently through the gap at the top, there appears to be numerous shards of old window glass which has made me wonder if they could have originally been glazed and maybe the cellar wasn't 100% submerged on the side walls when built which is quite possible given the slope of our garden.
Any thoughts?
PS. Apologies for images being a little wonky - sometimes this happens, from the original orientation and I cannot find the option on here to rotate??!
Any thoughts?
