A
Anonymous
Guest
I think I've discovered the cause of an area of dampness in the kitchen of the cottage we're renovating. I climbed on the roof of a single storey section to investigate some dodgy looking areas of pointing and patching on the gable end. The area pictured is directly above the dampness in the kitchen and it seems rainwater is penetrating and percolating through the wall.
As you can see from the picture, the wall is in pretty poor shape with cracks, gaps, bee holes and very soft crumbly bricks. In one place, missing or damaged bricks have been replaced by expanded foam which was simply rendered over. I assume that all the nasty cement based mortar has accelerated and exacerbated the deterioration of the bricks?
The question is, should I cut out and relplace all of the crumbly bricks and repoint with lime mortar or can some of the existing bricks be stabilised somehow? I'm worried that once I start chopping out bricks I'll end up having to take down a large area of wall.
Also, what is the best way to deal with the existing cracked and loose cement flashings at the top of the gable? Can lime mortar be used for his purpose or is it better to use a metal flashing?
