Just wondered if someone could give me a bit of advice about putting down some board to make a crawl way through my loft.
This is an old chapel Sunday school building (1880) and the loft is in excess of 50ft long but not high enough to stand up in as it is effectively the space above the “collar rafters”
These 4 x 2 horizontal collar rafters are fixed to the face of the 4 x 2 pitched roof rafters to form a triangulation. The spacing between the collar rafters is about 340mm centres.
The loft space or roof void is therefore effectively a triangle which is just under 3ft in height at its centre diminishing to nothing over its 7ft width.
Fixed to the underside of the collar rafters is the lath & lime plaster ceiling of a 50 ft long room which was once the school hall. So when you look up at the ceiling from this room, 15ft above you, there is the flat ceiling running down the centre fixed to the underside of collar rafters (roof void above) and an adjoining pitched ceiling either side (fixed to the pitched roof rafters).
I have three questions :-
Firstly, could you advise me if it safe to put my weight on these collar rafters as they would only appear to be secured to the main roof rafters with a couple of large nails either side (original 1880 construction)
Obviously someone has been up there before because the space is fully insulated with rolls of thermal blanket between the collar/ceiling rafters not to mention cabling to lighting etc.
Secondly, if it is safe and I am able to install a board crawl way along the length of this roof space, what’s the best material to use with regard to strength, lightness and cost? Someone has suggested either cutting up ply board or using chipboard flooring sections which I think come in a standard size of about 1500mm x 600mm (t&g).
Lastly, the thermal blanket insulation is quite thick. It’s pink in colour and stands a good couple of inches proud of the collar/ceiling rafters. I’m concerned that if I lay and fix down some board, particularly 600mm wide flooring chipboard, I would have to apply pressure to squeeze the thermal blanket down between the ceiling rafters which perhaps may be too much pressure on the old lath plaster ceiling below.
Assuming I can put a crawl way in this roof void, would it be advisable to use a narrower board, remove the insulation where the board is to be laid and then lightly stuff some insulation under the board once its fixed down.
I hope accessibility is an option here. The space needs a dam good clean out from roofing debris etc and it would make an ideal service route for running TV aerial cables etc.
Thanks in advance for your advice
Mike
Mike
