Lord Frederick III
Hi,
We purchased part of a mansion built in 1801 which has, until recently, been costing a fortune to heat. We've done as much insulation as possible (loft, double glazing etc), which has resulted in significant savings and all that is left now is to insulate the crawl space under the lounge.
The lounge is approx 8m2 with a parquet floor. The air vents push air into the crawl space, and this air then can be felt rising through the parquet flooring. Fine in summer, but not so ideal in winter. There are four options available:
The later is the preferred option, although the other half would prefer a carpeted floor. The only issue with insulating is that the air vents are just below the floor. So if we were to insualte, the air vents would either get blocked by the insulation or still vent between the insulation and floor (they are big vents). Ideally the air vents need to ventilate under the new insulation which may be possible by using a duct to redirect the air flow under the insulation. We don't want to block the air vents as they have kept the crawl space and cellar dry. We are concerned that by insulating in the crawl space that we may introduce thermal bridging and all the associated problems with it.
Does anyone know of the recommended approach when it comes to period properties and crawl space insualtion? Happy to take recommendations for insualtion specialists in the Yorkshire area.
- Do nothing and keep the heating on high
- Get rid of parquet floor by adding themal underlay and carpet over
- Add under floor heating. Not ideal for solid wood floors
- Keep parquet flooring and insulate under floor using Kingspan or equivalent
