Geoffrey
- Oxfordshire
Wow - you go away for a few months and everything's different when you come home.
Hopefully you're all stilll as helpful as you have been in the past, so here goes.
I've just removed the lining paper from my daughters bedroom ceiling (ok so it removed itself mostly). The old wobbly lime plaster ceiling is pretty good for 3 or 4 hundred years old but has some cracks. Should I use a lime mortar to fill them or will something like polyfilla be ok.
I was assuming I should scrape out along the cracks and then fill, but it might be less disruptive just to fill the cracks as they appear on the surface. I don't want to tempt fate and cause more of it to work loose from the laths although as I said it seems pretty sound.
Many Thanks in advance
Geoff
Geoff
