Hi all
I've been browsing this forum on and off for a couple of years - since I bought my current house.
I bought an old (circa 1780) cottage over 2 years ago. It was a small cottage with an extension added most likely shortly after it was built and a long single story extension at the back, which was originally used to keep chickens and was converted into a living space over time (in 1986). The house has its fair share of various issues and shoddy DIY but recently I got slightly worried as over the last few weeks a lot of cracks appeared on internal surfaces. They are anything from hairline to about 1mm wide and follow straight lines between walls and ceiling, walls and floors, around windows and doors, between panels on the ceiling etc. After browsing this forum I'm 99% convinced this is due to changes in temperature and humidity. In the spring we installed a new boiler, replaced some of the radiators and fitted a woodburner in a previously completely open fireplace, so the house is now a bit warmer and there is less humidity (the meter that used to show humidity almost constantly above 70% now shows 60-65%).
What worries me a bit is the fact that a lot of those cracks appeared over a relatively short period of time (around 4-6 weeks) and new ones keep appearing.
The other thing is that the house is built on a very slight slope and the floors on the ground floor became more uneven (they were uneven to some degree before) so I'm worried a bit about movement. This is especially true in the single story extension.
When I bought the house, the structural survey said that there are signs of movement but they are typical for such an old property and appear to be historical. The house had diagonal cracks visible on the external walls, which were filled in and painted last year... these cracks gradually reappeared over the next few months but are no bigger than before. No new cracks appeared on the external walls.
Does any of this sound like a potential bigger structural issue? Can anyone recommend a structural engineer specialised in old properties bases in Cambs/Suffolk/Norfolk (I live in Lakenheath, between Newmarket and Thetford)?
Many thanks!
Andy
Many thanks!
Andy
