A cracked victorian concrete window sill has caused the wall right below it to develop a wet patch, with a diametre of about 1metre. The moisture already shows up in the bedroom of the floor below.  How would this be best repaired, we do not want to spend much money and Builders in London tend to quote a fortune. Could the crack in the sill be sucessfully repaired with the right mix of concrete ? Or is it better to cover the whole sill with a made to measure metal sheet ? or bitumen ?
Thank you for any advice
