nighttrain123
Any thoughts on this? The surveyor said it's just cracked render, not structural, and is a cause of a little damp under the upstairs window. Long term the render would need hacking off and replacing. I'm a bit of a worrier but what's the worse the brick work could look like? Other terraces in the row with naked brick look decent enough.
The property has modern PVC windows and it looks like at some point the masonry sills were either shaved down or removed (not sure why? Got slightly shorter or longer windows cheap?). The masonry lintel is hiding under the render I believe. Next door is also rendered but retains original sills and the lintel is painted only, with render not covering it.
If the sills were removed it would look rather unsightly I'm guessing with later brickwork filing in the space? So if the render would need to back on to stop an eyesore. The surveyor said use a polymer but this is some time off if it happens. I understand sand-cement a poor choice for sold brick walls although once was all the rage.
Another terrace in row with naked brickwork and original masonry.
The adjacent property, rendered but with lintel painted and original sill.
