Our 1950s property was once Mock Tudor (brick on ground floor, rendered and cosmetic timbering on upper floor). At some stage in the past, for an unknown reason, the cosmetic timbering has been removed, and infilled with render, and the ground floor has been rendered.
As the house is on a slight hill, on a clay over chalk soil, and has a mature birch tree within 4 m of the house, there is some movement and the rendering is covered in small cracks, including where the timber was removed. We have patches of damp at intervals on the worst wall, which I am sure are caused by water penetrating the cracked rendering.
We also have mouldy patches appearing behind bedroom furniture, which, after reading a lot of this forum, I suspect may be caused by the rendering trapping condensation, even though the windows are open at night
I should add that the walls are not cavity walls.
Also the internal plasterwork is rather strange, being of drill-breaking hardness.
My questions are:
Would lime-based rendering be suitable for a property this age?
Would it cope with the movement of the house?
Would it solve the water penetration and mould problems?
Can anyone provide an approximate cost per meter squared, including removing old cement rendering?
My questions are:
