I wonder if anyone out there could help me with this little quandary.
We live in a 200 year old stone built house. One of the rooms is built partially below the external ground level by approximately 2-3 feet. One wall is tanked but under heavy rain conditions rainwater seeps through into the room at the base of the tanking on to the original quarry tiled floor. In addition there is often a strong damp smell when it has rained even if the floor stays dry.
A damp specialist company has recommended fitment of a cavity membrane and an internal drainage channel to stop the water ingress. I think this sounds like a solution but they have also recommended covering the quarry tiles with a two part epoxy membrane. I am uncertain about this. Is this necessary?
The quarry tiles themselves will be damaged when the drainage channel is put in plus they are not in the best of condition anyway but I am concerned that the floor would no longer be breathable. Is this likely to cause other problems?
Any comments would be gratefully received.
