I own an old Baptist chapel on the south coast which is pretty much in its original form. It has a sunken baptising font (full emersion) and balconies at first floor level on three sides complete with box pews. According to the records The chapel was built in 1817 but having carefully removed a few t&g panels here and there to expose sections of brickwork, I am lead to believe that the gable end stucco frontage of this building with its neo classical features was built sometime later not only to give the building a fancy frontage but to also form a full height front extension creating a new entrance lobby and an extended balcony above.
I’ve just been lifting sections of floor boards in the “extended” balcony to clear debris and dust from under the floor voids and to check the timbers and I think my suspicions about the later extension have now been confirmed. I found an off cut of wood under the floor with what I can only presume is the carpenters name scribbled in pencil and dated May 23rd 1873. So it would seem that the frontage and balcony extension were built some 56 years later.
What I’ve also discovered below the balcony floorboards is one of the supporting beams which is a solid piece of timber about 6”x 6” square and about 20ft long held at various points from the ground floor below by a series of painted metal columns probably cast iron. Whilst most of the timber in the chapel is pine, including the wall plates, this wooden beam under the balcony floor is rock hard so I suspect it is probably oak.
One of the curious aspects of this beam is that it has a regular series of square holes in its top face each 2”x 2”square x 2”deep spaced approximately 1ft apart and there seems to be no apparent purpose for them. Considering I’m in a south coast location, I did wonder if this might be a piece of salvaged ships timber installed in 1873.
If so, are there any shipwrights out there who might know what part of the ship or boat this might be?
I’ve noticed just a couple of small areas of what might be woodworm (dart board holes) in the top face of the beam, so I’m thinking that I should perhaps treat it just to be on the safe side. Any advice on what to use?
