The external ground level against one wall of our c18 Cotswold stone house is around 5'. The large inglenook on the other side of the wall is damp. We recently removed unsightly concrete render from inside the inglenook (sides and floor) to reveal red brick on the walls (again pointed with cement) and orginal flags on the floor. The inglenook was subsequently plastered with multi-finish (We asked for lime and are now in dispute with the plasterer but that is another story! He says it makes little or no difference given what's underneath). Alcoves on either side of the inglenook have air bricks (not sure why as they are well below the exterior ground level) and the multi-finish here is totally dry.
We are planning to install a wood-burning stove but am at a loss as to how to prepare the inglenook.
Do we try to banish the damp with the use of a membrane (Newton or similar) or will the stove and the increased air circulation solve the problem for us. Will the stove gently dry the multi-finish or crack it? Would the result be the same with lime or would lime be an appropriate finish for this combination of damp and heat?
So many questions, too little experience. Any and all advice gratefully recieved.
Thankyou!
Thankyou!
