Hi, we have damp (of course) in our Grade 2 listed building - see full details below. Previous works (ie what we did when we moved in 10 years ago) following the surveyors advice was to construct a land drain across the front of the house and reduce the soil height by two feet (!) at the back, and then see what happened. This was done by a specialist historic building company, not regular builders.
There is a small area of wall at the front of the house that is still damp, although the levels are lower than they were at one point. This is at the base of the wall - bubbling disintegrating plaster, interior bricks along the bottom crumbling away etc.
We have had two builders suck their teeth and say 'don't know about that' and a damp survey that suggested just taking the wall apart just to see what is going on. When I phoned them the conservation officer was not happy about that idea! What we probably most need is a recommendation for a specialist contractor in our area that can actually work out what best should be done, propose a plan for the conservation officer, and execute it! I've contacted quite a few with no success.
Tips on things that should NOT be done would be helpful. (We know it shouldn't have a DPC put in!)
MORE INFO
It is a timber framed house approx 1600. The walls are very thin, the outside is inappropriately cement rendered and the inside covered in plasterboard as far down as the sole plate. The exterior base of the wall on the non damp areas is brick painted black with bitumen (presumably). The base of the wall on the damp areas is of unknown construction and much lower in height than on the brick base side of the house. The whole of the front of the house is probably a few inches below ground level; it is gravelled outside. There are no plants close to the house by the damp area. The floor inside is slate slabs,we don't know what they are laid over, I'm guessing concrete. it's a dining room with lots of ventilation (via a massive chimney).
A friend who has done restoration himself says the rainwater goods look OK to him as far as he could see without a ladder, there are no cracks or staining on the exterior render, and the exterior bitumen paint on the base of the wall looks OK. He thinks that the timbers are OK at the moment.
One possibility that occurs to me after reading the FAQ on here is simply reducing the height of the soil outside. But by how much, and how long should we leave it to dry out before repairing inside? And then should it be with breathable materials on that area of the wall?
MORE INFO
