Can anybody advise which company produces the most authentic looking cast roof lights i.e. those most resembling original cast iron rooflights? I've been looking at the products produced by "The Tuscan Foundry" They originally produced two types of conservation roof light , a Cast Aluminum model and a Pressed steel model called the Lumen. The cast Aluminum model looked the most authentic having quite a deep upstand when viewed from the side but a very narrow frame and glazing bar when viewed face on. The pressed steel model on the other hand was the complete opposite being very thin and flush to the roof line but with quite wide, flat frame sections when viewed face on and looking altogether much more modern than its cast aluminum counterpart. Unfortunately
“The Tuscan Foundry” are no longer producing the cast Aluminum range and can only provide the latter pressed steel models. I also need to check "Clement windows" aka "The Cast Rooflight Co" who produced a similar range but I believe they too are now only producing a less convincing pressed steel version.
