I have an old and now unused cast iron soil pipe on what was once the outside of the back wall of the house, but a more recent extension built on the back of the house means that this soil pipe is now internal in the extension.
I would now like to add a WC and sink into this extended part of the house and connecting to this old soil pipe seems to be an easy way of getting the drainage I need without having to dig up the nicely laid brick floor in that room.
But, how do I do that? I'm not aware of any way that I can connect a new 110mm plastic pipe to the side of the existing cast iron, is there any way of doing this that people know of please?
Or, I could cut the old cast iron pipe at ground level and remove all the redundant part above, then insert one of these type of connectors and then use pvc pipe to connect to my new WC. But, by the time I have inserted that adaptor and then an 87.5 degree bend as well to take the pipe where I need it, its height above the floor will be too great by the time I get to the WC. A solution would be an 87.5 degree bend that connects directly into the cast iron that I cut off at floor level rather than using the adaptor that I linked to above, but I can't find any such bend, does anyone know if they exist and where to find them?
Or, any other suggestions on how I can resolve this will be much appreciated please.
