Nigel Watts
- London N7
Now that I have nearly sorted out my Baconesque loo problem thanks to your help I am now feeling confident to tackle some more plumbing issues which I have long been putting off....
1. A year or two ago, when mending floorboards, I managed to nick a copper central heating pipe with my chisel, causing a small but troublesome leak. The pipe leads to a radiator in a room earmarked to become a bathroom one day but still in use as a store room. There happened to be an isolating tap in that same pipe run, so I turned it off, and it has stayed off ever since. Is there a solution which does not need soldering skills?
2. Hydraulic hammering is a regular occurance in the heating system, especially in the bedroom radiators. The system was completely replaced about five years ago but I guess it has got out of balance or something. Is this solvable by an ignorant amateur like me?
3. I have an old gas pipe under my living room floor leading to the fireplace, which used to have a coal-effect gas fire. I have long since replaced the grate with an antique one which burns coal and at the time I instructed the builder to disconnect the gas. A year or two ago I thought I would remove the now redundant gas pipe and tap at the bottom of the grate, which for some reason was still there. On starting to unscrew the joints I was met with a loud hissing sound and gas smell, so I rapidly screwed it back together again. The builder clearly had not followed my instructions to disconnect the supply. I regularly light coal fires in the grate, some six inches above the postion of the (live) gas tap. There have been no explosions so far but is this really safe? I guess fiddling about with live gas pipes is one for the pros?
4. I have an outside tap which is screwed on to a fitting at the end of a horizontal length of copper pipe. The only way to stop it dripping is to ensure it is tightly screwed on. This results in the tap being in a rather unconventional horizontal configuration which is both inconvenient and casues the wall to get damp. How can one get it to be both vertical and watertight?
Any solutions would be much appreciated!
