DaveBlair855
All,
Have had a quick blast through the search engine for a solution to this but got a staggering number of hits, so forgive me if I'm covering old ground here.
We have a 16c thatched cottage which has been subject to some "renovation" (read "negative interference") by the previous owners, part of which includes the replacement of a number of the panels between the beams on the first floor with some form of cement render. The result- very cold walls on the North face of the house, which in turn is causing real issues re condensation and the dreaded black mould. This problem is presenting on the first floor landing and to a lesser extent in both first floor bedrooms- the ground floor seems untouched.
I have had the place assessed to ensure that there are no other underlying damp problems and am assured that this is purely a condensation issue caused by inadequate ventilation. We have had the heating in the house re-vamped, although not excessively so, and have also replaced the bathrooom since we moved in.
So the question is this, how best do I improve the ventilation on the first floor to keep the air on the move? I would prefer passive systems as don't really fancy a dehumidifier running all the time with the accompanying expense, but am not sure how this stands with regards to the listing in effect on the building- presumably it will require a degree of hole knocking in walls? I imagine even an extractor fan would assist, but don't know how a CO would react to such a proposal.
Any advice or experiences gratefully received.
