I’ve just been up in one of my lofts and there’s lots of condensation droplets on the underside of the roofing felt which are obviously dripping as my newly installed 18mm ply board ‘crawl way’ is very damp.
This loft is above what is now a ground floor, single story bedroom, corridor and bathroom and consists of a single elevation ‘lean to’ felted and slated roof i.e. the roof leans against a solid brick wall sealed at the top with lead flashing.
The loft space is about 10meters long by 2 meters wide with a maximum height of around 1.5 meters (against the lean to wall) tapering down to nothing towards the gutter line.
There are about three ventilation points along the length of the roof. I don’t know what they’re called but they are slate sized plastic panels with a vented mound on top.
The loft floor (lath /plaster ceiling of the bedroom, bathroom and corridor below) is insulated with rock wool
This is an original structure from about 1817. Interestingly there is a cavity wall along the back elevation (the wall which the roof leans against) from ground to ceiling level. At the bottom of this wall (at floor level) there is a series of original terracotta grates or large air bricks which allows an air flow from the rooms, up through the cavity and into the loft space. At the moment the loft is very cold and so the cold air from the loft is coming down the cavity and through the grates into the rooms. Previous owners had installed hit & miss grilles over these air grates to stop the cold air from the loft entering the rooms. I have in the main left these grilles open as the original grates must be there for some reason.
Not sure what I should do here to stop the condensation in the loft. Should I allow the flow of air between the room and the loft to continue or should I seal it off. As mentioned above when opening the hatch to climb into the loft, it’s noticeably very cold up there.What were these original grates in the wall for? and would it be detrimental to close them off? the rooms in question are efectively below ground level as on the other side of the lean to wall, the pavement and road align approximately with ceiling level (the building is on the side of a hill)
My guess is that its warm air from the rooms condensing against the cold roofing felt in the loft space so perhaps the terracotta grilles in the cavity wall which allow warm air in the rooms to travel up into the loft space was an 1817 design blunder?
