1934norfolk
Hello, I am new to the forum. I look forward to reading and getting involved, looks like a treasure trove of information.
We bought our first house about 18 months ago, its a 1930s detached house, not sure if this fits in the definition of period property? What we thought was going to be redecoration is now turning into a full refurbishment / restoration!
Anyway, onto my query. The original ground floor of the house seems to consist of a concrete floor with a bitumen layer and then timber floor boards on top. Currently some of the floor has an engineered timber flooring which has been laid on top of the original timber floor boards with a membrane in-between.
In the areas where I have exposed the original floor boards they are generally in good condition. There are some areas where the edge of the timber has touched an external wall and it has started to rot. There is also a small area of the floor which is close to where the front door was originally located, this also has some small rotten areas.
The ultimate goal is to tile the hall area and have a timber floor in the living areas. Unfortunately due to past wall removal and a 1970s extension the original timber floorboards are not continuous throughout the living area.
My question is - should the new flooring be installed on top of the old floor boards, like the current engineered floor seems to be? If so, presumably I should cut out the rotten bits and patch up the bituminous paint?
Or should the floor boards be removed? Is the bitumen likely to be the DPM? I suspect it is. If the floor boards are removed, how should the floor be built back up again? Should the bitumen also be removed?
I should point out that we plan to be in this house long term, 25+ years. Although I don't want to spend money for the sake of it I also want to do things right first time.
Hope someone can help. Cheers, Chris.
