Does anyone know of a calculation that exists to get an idea of the size and thickness of oak beams required to support an upstairs room/
I'm concerned about the strength of the beams in our dining room. Above it is a spare bedroom. The dining room is about 4.5m across with a good, chunky central beam spanning the width about 2.5m out from the wall across the middle(ish) of the room. The smaller beams running from the external wall to this beam are what's concerning me because they feel a bit bouncy in the room above which has a very wonky floor.
They're not evenly spaced and I think there should, in an ideal world, be a couple more of them. There are 7 of them in total. They range in thicknesses of about 10-12cm wide and, I'm guessing/hoping about the same high but I can't gauge this from below due to the ceiling. The gaps between the beams range too. The two that run along the wall have a gap of about 16cm between them but others are 55cm apart. I think this is because there used to be an oak screen dividing the room until a few decades ago and we think the stairs were in a difference location in there in its history so this would have dictated where the beams are today. Should they be evenly spaced?
Another concern is that where these beams join the main beam, they've been reduced in size by 3-4cm vertically and then slotted in to the main beam. In my mind, this makes them less strong.
One or two of them have been reduced in thickness (vertically) along their length and you can see these flex when someone walks above.
The floor above has been chipboarded with carpet on the top. We'd like to change this at a later date back to floorboards. I know these beams been there for hundreds of years and many generations of occupants but I want to make sure that the house is structurally good. It occurs to me that people are bigger and heavier these days and so are we put more "stuff" in our houses so I wonder if this particular floor needs attention?
Any helpful thoughts are welcome.
