Matd said:After removing some plaster (i say removing... it almost removed itself :roll: )
I discovered that an internal wall does not tie into the exterior wall.
Is this common practice, bad build or typical of a wall added at a later date ?
Common practice? Pick any building technique and you can be sure that it will have been used in any variety you can think of - plus a few that you would never have considered possible.Matd said:an internal wall does not tie into the exterior wall. Is this common practice, bad build or typical of a wall added at a later date ?
