vicky whitworth
- East Devon
Hello, I wonder if anyone has any views on oil combi-boilers to heat hot water and a central heating system? Our concerns is...we are installing a cast iron bath and we like lots of very hot water in our bath. Will a combi-boiler be able to heat sufficient water hot enough and quick enough? We had combi-boilers in flats in the 1980s and they were very slow flow to get sufficient hot water. Out plumber tells us they have improved since then. Also when the central heating is running would that impact on the amount of hot water we could get through to the bath? We would prefer to move away from an electric immersion heater, which is what we use at the moment as it needs space for the storage tank but we do know that the immersion gives us plenty of hot water at a fast fill rate.
Any thoughts gratefully welcomed.
Vicky
Vicky
