Feltwell
- Shropshire, England
Hello all,
A 2 part question here, the safe one first!
My house needs re-pointing, currently it is mish-mash of patches of badly eroded original lime and patches of cement. It will be re-pointed in lime, but the white colour is an issue.
The house was originally pointed in a grey colour by the look of things - it certainly wasn't white all over. You can see where certain architectural details, such as brick arches on the front elevation, were picked out in pure lime white pointing. Having re-pointed a little already around window reveals, the resulting white pointing looks odd. Any tips on how to colour the lime pointing mix? It looks as if it may originally have had coal ash mixed in with it, but I have heard that this weakens the mix.
And now the dangerous question!
I'm just getting quotes in to build a garage next to the house. It's not intended in any way to be a faithfull recreation of a Victorian building - it has been designed to blend in aesthetically with the house, but will be built with current methods, e.g. block and beam floor, pre-fabricated roof trusses, cavity walls etc.
Cost is a major issue and so is availability of builders willing to use lime, as I don't have the time to build this one myself. I could try and get the outer brickwork built with the same lime mix as is used to re-point the house, or I could go for cement for cost reasons and ease of finding a suitable builder. But if I go with cement, how best to make it look like the house pointing? Use snowcem and the same colourant as the house?
My flame-proof suit has been donned, I await the cries of derision and casting out into the cement-riddled non-green world of the new builds!
