John&Lou
Hi folks
Hopefully, some of you who live in period properties may also have one of these burners in their house and may have experienced a similar problem to ours?
The firebrick at the back of the burner disintegrated, requiring replacement. It was quite easy getting the old brick out - after all, it was in pieces. Getting a new brick in was a bit of a mare, as the brick extends to the full width of the burner. There are a number of screws on one of the side panels of the stove, which I thought could be used to remove the side and insert the brick. Unfortunately, I couldn't get the screws to turn and I didn't want to force or drill them.
In the end, I cut the firebrick and cemented the two halves together in the burner. Not ideal and now the cement joint is coming apart.
Has anyone else had this problem and is there another way of getting the firebrick into the burner? By the way, I didn't pay hundreds of pounds on the Aga firebrick, I got a cheap alternative off eBay.
Thanks in advance
Thanks in advance
