Feltwell
- Shropshire, England
I'm having to re-build our gate piers, as both are leaning by an increasing amount each year.
The stone blocks halfway up each pier are, not to put too fine a point on it, "mullered". Half of what should be stone is cement mortar - the original cast-iron gate fittings put into the blocks have rusted and blown the blocks apart.
So new ones have been ordered in a stone from a local quarry which should, after a good few years of weathering, look the same as the originals.
The question is - the pier caps, which are OK to re-use, are stained green from where they sit under the trees:-
To clean or not to clean? Opinions? Bear in mind they will be sat above shiny new blocks of stone.
And if to clean, how? I had a brief go at one section with a scrubbing brush and plain water, it did very little!
