after stripping off all the cement render from my clay lump lean to i noticed one of the walls has very bad water damage at the foot of the wall. the first two courses of clay lump has turned to sandy rubble. the wall is leaning badly.
the problem with this wall is it is the exterior wall however there is a block extension built beside it.
i need to replace the clay lump blocks that have rotted but can i do it in situ or would it be best to dismantle the wall then re-build it?
this is the wall,
this is it in the flesh.
that water butt in the last pgoto was over flowing for two years and the water soaked the base of the wall , i suppose the cement render didn't help either.
so , do i take it down or can it be fixed in situ? either way i am not too bothered but easiest is always best.
this is the wall,
