CliffordPope
The other thread on chimney problems prompted me to ask my own question.
We have a solid-fuel range cooker in the kitchen, with an insulated flue running up the outer corner of the house on the inside. At the top just below the roof the flue does a gentle double bend over the top of the gable wall and feeds into an old brick chimney stack on the corner of the house. To get enough draw height a cast iron flue is cemented inside the stack and projects above the top of the bricks by about 2' 6", with a removable cowl on top for annual access from above to rod out the bend lower down.
The rather inelegant iron pipe has a traditional chimney pot stuck over it, a few inches shorter than the pipe, which projects far enough to accommodate the cowl.
Some years ago I cemented a pot into position to hide the pipe, and filled the annular space between the pot and the pipe with cement to stop any water accumulating inthe void.
That was fine for a few years, until recently a crack appeared in the chimney pot and a section of it fell off. I would guess what has happened is that the combination of damp, frost, heat, differential expansion and rust has exerted pressure and cracked the pot.
Now I am wondering what to do:
1) Accept the appearance of the iron pipe, chip off the remains of the pot, and leave it
2) Get a new pot, and try again
3) Get a new pot but leave it loose
4) Cement a new pot firmly at the base, but leave drainage holes
The pot is purely ornamental, hiding the pipe. It plays no part in the draught process, and does not support the cowl.
What would you do?
What would you do?
