Westholme
- Gloucestershire
http://oi68.tinypic.com/mvreav.jpg
The stack is halfway along the party wall at the rear of my house. My neighbour and I would like to see it removed. It's sad, I suppose, but there are no fireplaces at all remaining next door, just the chimney breast sticking out 12" and getting in the way both sides, especially upstairs where it is much wider than downstairs.
Can anyone recommend a good roofing company in my area? My plan is to have the stack removed and roof patched professionally, then remove the chimney breast below roof level myself. Am I right in thinking that building control do not need to be involved if the whole lot goes?
As you can see, the stack is 5 bricks long by 3½ bricks wide. (A brick is 9" by 4½" approx.) The original slates have been replaced with concrete my side and fake slate next door. I can get concrete ridge tiles to match, covered in moss and lichen, from a local reclamation yard if needed. There appear to be three below the flashing. The rooms upstairs have a partially sloping ceiling and if there were a hole in the roof in front of the stack, I could stand up in the roof space with the top half of me sticking out.
I don't know the exact dimensions of the flues. Is the party wall likely to be one brick thick right up to the roof ridge?
