A
Anonymous
Guest
We have a 300 year old stone and thatch cottage. There is an inglenook with an open fire in the sitting room. We've been using this quite a bit with the cold weather and had it lit the other day. Standing in the garden looking up casually at the chimney, we could see smoke leaking out through the stack near the top but also, more worryingly at the base where it passes through the thatch. We immediately extinguished the fire and checked there was no smoke coming into the roof space (the flue inside appears sound).
We now plan to have the chimney rebuilt (it's rather wonky as well as the failed mortar issue) and are wondering whether to line the chimney where it goes through the thatch as an added precaution.
Does anyone have any experience of lining (or part-lining) a chimney with a flexible liner? How, for instance is the liner secured at the top and bottom of the lined stretch, and should it be back-filled with vermiculite - and if so, how is this held in place?
Grateful for any ideas/advice out there.
