I've discovered a purlin sitting on the back of a chimney ! The masonary around the roof line is shot and i can see the flue liner from the room the purlin is in. There is some smokey deposits on the wood and surounding roof structure but no charring (tho I haven't been able to inpect the end that is actually in the chimney) We've used the fire that uses the chimney regularly for the past five years with no problems. Should I fix up the masonary and forget about it or do something else to remedy it ?
