citizensmith
- Herefordshire
Anyone got advice on this one?
We have been working to fit flooring in our loft above the downstairs breakfast room. The room is an old extension to the house and contains a chimney breast that passes up through the loft.
When we started it was incredibly filthy work and we were coming out black at the end of each session.
Now we can see better, i see a fair bit of damage to the chimney breast in the loft. It looks distorted, the bricks at the top in one corner are loose and separating and there is a 1/2 inch crack in the lime plaster running for about 5ft diagonally across the face of the chimney. When i poke a scredriver in the crack it dissapears completely - so is not just a surface crack.
The house is pretty big - this chimney breast has 3 flues in it and is very confusing to work out. The bit i am describing does not appear top be taking the full weight of the stack as it steps inwards at the top and then continues up for another floor.
Questions...
Do we...
1. Remove the loose bricks until things look more solid and then rebuild the loose corner.
2. Do we use conventional cement mortar?
3. If things are stable - can i simply repoint the crack and replaster to seal the chimney?
This part of the flue is connected to a rayburn which we do intend to light now and again - is this wise?
I am not sure if lining with a metal tube is much of an option as the total stack is 50 - 60 ft with 3 kinks to follow? Can this be done?
Sorry for the ramble, but i am fretting over this discovery :!:
Questions...
Do we...
