Hi all, sorry have been missing for a while - mainly because I've been spending my time looking to see what my walls are all made of!
Took 5 layers of woodchip off the main sitting-room wall. The wall has a vertical stud, then a panel, another stud, then a long panel that has two internal studs, another stud, final panel.
I haven't stripped the first panel yet, but the second is lime plaster over daub. Got a bit of a shock when I thought there were wall paintings (of the oh please no type shock) but the paint goes over some very modern polyfiller so that sorts that! There was a large piece of modern plaster - about 2ft square - in one section, so I broke a bit off and it's filling a hole in the daub that goes right back to the laths. The laths aren't like wattle, nor are they like the ones I've seen in lath and plaster. Very strong, straight batons basically - no worm or anything. Stuck the camera through the hole and it's the space between us and next door - few spiders, spare batons and bits of lime plaster but that was all I could see,
The end panel is fibre board. Everyone said that removing woodchip was hard, but this stuff just fell off easily.
Husband is obviously thrilled with the sitting room wall being old splodgy plaster with chunks missing and holes where chunks of polyfiller were!
I have a few pieces of lime plaster that 'came away in me 'ands doctor' that I want to reattach as they're in good nick except round the edges. Some of the lime plaster was hanging away from the daub, but I found that thoroughly soaking it with a sponge and very slightly soapy hot water seems to have reattached it and it doesn't look any different on the surface. Is there a way of sticking the bits back together?
The plan is to replace and fill all the holes and skim the whole wall with lime plaster. The hole probably needs to have new daub made. Can you buy pre-mixed daub in the way that you can but pre-mixed lime?
Also, the daub seems to be in sheets - a bit like plaster-board - rather than worked into a frame. Does this sound odd?
Then the chimbley...
I 'just happened' to be looking behind the chest of drawers in our bedroom where there is a blocked in fireplace. There is a vent set into the plaster and lots of black duck tape over it - or rather falling off it - and nasty brown marks down the wall. So, I ripped the tape off and unscrewed the vent. Then removed 2 heavy duty bags of twigs and other crap. Stuck my phone in and took a load of pictures and you can now see all the way up the chimney. The condition looks really good all the way up on all sides.
The vent is about 2ft up from the floor and it appears that the whole part under the vent is full of dust and chunks of brick and plaster. I've taken a gazillion pics up the chimney and I can't work out where the bricks could possibly have come from as it's totally smooth with no missing ones.
The front of the fireplace has a half inch of modern plaster - so I chipped a load off
- and underneath are some badly done brickwork. The fireplace has a small bressumer and bricks to either side (sadly someone has knocked the faces off most of them).
I've poked about in the gunk under the bottom edge of the vent and it looks like the lovely brickwork at the back carries on down.
I'm wary that perhaps the whole fireplace is held up by the rubble at the bottom. Am I being stupid? All of it moves, the bricks just seem to be lying there on the top of the gunk.
Given how nice the brickwork is inside, I'd like to open the fireplace back up.
Is there anyway that I can find out if the stuff in the space - the back of the chimney is about a 1.5 feet from the vent, depth to floor is about 1.5ft and it's about 5ft wide. Could 1.5ft of dust with bits of brick and plaster in be holding up the whole chimney or am I being unnecessarily cautious?
Any thoughts?
Any thoughts?
