GeoffP
- Derbyshire
Not strictly a “period” subject but can I pose a few questions to all you qualified plumbers out there.
Basically, I have a large draughty Georgian farmhouse and I’ve recently installed a large, up to the minute, Combi Boiler for my hot water and partial central heating system but, like most of us, I am concerned about the cost of gas used by trying to heat my house more efficiently (cheaply) in the coming cold months.
Having a good local supply of logs, I have converted most of my rooms to use open log fires with one having a multi-fuel (log) burner but these are not all lit all of the time and the central heating is necessary when it’s cold..
My questions are :-
Can I connect a boiler in my log burner directly into my C/H system (in effect, like another radiator) and heat the water before it goes into the Combi thereby reducing the amount of gas needed to bring it up to temperature?
To make this feasible, I would think that the circulation pump would have to be running at all times when the fire was lit so as not to overheat, so I assume I would have to fit a thermostat to switch on the Combi pump?
I doubt that the temperature would get too high when the system was running but if so, I always have room for more radiators.
I would also think that any venting or pressure problems would be handled by the Combi boiler, any comments on this?
Thanks in anticipation,
Geoff
My questions are :-
Geoff
