Some time ago I posted a problem about removing an "artex-type" finish from a lath and plaster ceiling. I'm not sure it was Artex exactly, but it was a stippled plaster finish covered in emulsion paint. Since then I have found a way of getting rid of it using a cheap home-made paint stripper that seems to work well on emulsion.
The new improved recipe is:
Put 7 litres of cold water in a bucket.
Add 170 gms caustic soda and mix thoroughly to dissolve.
Sprinkle in a sachet of solvite heavy duty pink wallpaper paste and mix as per packet.
Use a wallpaper paste brush to apply.
It sticks to the ceiling/wall and the pink colour shows you which bits have been covered.
Leave for about 5 hours then use a stripping knife to remove.
Wash off the residue.
Be very careful using it and wear goggles, rubber gloves, overalls etc. I suspect it would take the hide off a cow, so don't get it on your skin.
