MetManMark
- Devon
All
We have had a few quotes for the installation of a new central heating system. It has some suspended floors downstairs and some solid floors. Some of the plumbers have recommended putting radiators in less than ideal positions such that you could do radiators back to back etc to minimise visible pipework - others have suggested just having 'drops' into each room. We had decided on the later (as they will probably be masked by curtains etc, however, the last chap suggested chasing out the walls to run the pipework beneath the paster (some solid walls with lime plaster - others are lath & plaster). My initial concern was wrt leaks but he suggested that they would be using a single pipe to go from above the ceiling to beneath the floorboard so there couldn't be any leaks in the wall.
We have yet to get the cost of any of these options but what are people's thoughts? What are the downsides to having pipe work in the plaster? Presumably there could be issues with expansion or vibration of the pipes causing damage to plasterwork?
Cheers
Mark
Cheers
Mark
