Hi all, first post on this board and a lot to engage with!
I'd like to call on someone's knowledge if I may. I am hoping to buy a Victorian property in Kent but can't do so without making some changes to the layout inside architecturally and would like to see where this has been carried out in similar circumstances before if possible. Not sure whether that suggestion is heresy to some of you, guess I may find out!
Anyway, I wonder if there's anywhere I might look online (or here? - can't find) to see where others have made changes to similar properties without drastically altering the overall structure?
Background: The property is a semi-detached with 3 floors one of which is a lower ground / semi-basement. It's quite a narrow building but with the expected high ceilings.
The sitting room is where you would expect on the ground floor by the front door (after the hall) and is OK sized but next to it at the back is a tiny room currently used as a very cramped dining room and behind this is what I assume is an (old slate roofed) extension that is single storey and houses the bathroom (and also has some very obvious damp issues).
The kitchen is downstairs on the lower ground floor(facing the back) next to what is currently the main bedroom (facing the front) - which is not ideal due to ventilation, smells etc as well as being quite dark.
On the first floor are three medium to small rooms used as bedrooms for the current owner's children.
Hence trying to see how I can open open up the space a little without changing it from what it is into something else.
The local area is perfect and the external structure is lovely so trying to compromise a little and see where tweaks can be made. Otherwise it's likely to be an Edwardian in a less preferred location or waiting on another property in this area with a likely 100% increase in the sale price from this current consideration..
Options to me seem to be putting an arch or similar into wall between sitting / dining room. Swapping kitchen with bathroom or perhaps digging out the back of the kitchen downstairs, putting in some steps and larger window to make it lighter and changing master bedroom on lower ground floor into a dining area. Perhaps even putting in a loft conversion..
WE need three bedrooms at the moment and four eventually..(I currently work from home mostly so need an office plus three additional bedrooms, two at a pinch).
Any directions to previous architectural genius or shenanigans much appreciated!
Ben
Ben
