JohnM
- Central Scotland
We live in a large old house that has been converted into 5 flats. There is a large boiler and about 60 radiators. There are two radiators on the highest level (second floor) that are a long way from the boiler and don't heat up. We've tried turning off a number of other rads in the house to increase the pressure and this does get them hot after about an hour, but after a couple of days they cool down again. We've bled them and as far as we can tell there's no air in them - however they have bleed valves that you use a screwdriver with rather than a key, and on one of them the screw doesn't tighten up. Is it possible that this valve is letting air into the system? Or could the TRVs on them be both faulty ? Any other ideas gratefully received !
John
John
