jimmyjamez
Hi
Just new to this forum and have looked through the numerous similar topics for an answer but I guess, like most, I have a pretty specific question.
We have purchased a c.1700 stone terraced cottage. The walls are stone with rubble infill. It was condemned in the 1960's but rescued by someone who renovated them using materials thought to be ok at the time (concrete floors, cement pointing, plastic based artex extenal render instead of limewash etc. Even though it was empty for a year or so prior to our purchase and there is no heating etc it surprisingly doesn't smell of damp and there are only 2 areas of small damp patches on the chimney breast. I have done some exploratory work (chop away some of the external render, chop out some of the internal cement based pointing) and found no evidence of damp inside the walls. The terrace is built on a rear-to-front slope so drainage is pretty good.
My question is do I need to chop out all of the cement based pointing on the internal walls and repoint in lime. We aim to just paint the stone walls with Earthborn claypaint so the stone should breathe to some extent. It would be great to replace with lime but money and time is tight and will still look the same once painted.
Similarly with the external render. i would love to remove it all, repoint in lime and re-limewash it but would take many, many weekends or lots of money to sort.
The concrete floors should ideally be replaced but no damp appears to be rising up the walls so I question the need to replace these.
Thanks in anticipation
James
James
