Hope the learned souls on here can help with a question re: our cellar.
Our house, built 1780, has a brick cellar. Obviously, it is a little damp and the floor construction has grooves around the edge to catch run off and channels this to a sump in the corner...all fine.
However, we have some damp on an exterior wall in a room above the cellar (not close to sump). Upon investigation, I found a large piece of slate in the cellar floor.....beneath this is what can only be described as a well of some sorts. Circular, brick construction and full of rubble and water. Even with the rubble in the bottom, it appears to have a further five-six feet of water above the rubble!
Since this is right against the wall, I'm guessing that the water is rising up the wall to the room above (no DPC). There is no concrete render, no external shubbery etc. to prevent evap'n to the outside...all pointing is lime.
So, should I fill the well? Could it be some kind of old soakaway? Is there another way of eradicating the damp above? I can live with the cellar being damp, but I need to sort the problem in the room above.
Pete
Pete
