Sorry for the second post in quick succession....been away and now catching up with the never-ending list of jobs at home ;-)
The drawing room ceiling (l & p) has a crack running in a straight line across the entire length of the room (40ft). Upon further inspection, it is directly beneath an internal wall between two bedrooms on the 1st floor.
It appears that the wall was built off the floor (and not above a supporting wall on the ground floor). It's also noticeable that on the first floor, the floor has sagged over time with the weight of this wall (which I believe is blockwork and not just a stud).
So, some questions......
1. Do I just leave the wall and repair the crack...hoping that it won't move any further?
2. Is there any form of structural support I can insert without major works to the first floor and the ground floor ceiling?
3. If the wall is unsupported (and recent..ie. 1930's not 1700's), what are the chances of LBC to replace it with a stud? Would this be desireable?
