Hi all, another question...
We have a ground floor 1890's flat, and as we love punishing ourselves we're thinking of ripping down the ceilings throughout which are lath and plaster construction and have been overboarded very badly - not skimmed, papered directly over, nail heads showing through, lost definition of the cornicing, etc - arrgh! While we're doing this it is clearly a good opportunity to introduce some insulation for both sound and heat as well as inspect the timbers above for signs of rot. Our flat is cold even in the summer so I'm dreading the winter and if the upstairs flat ever take their carpets up then the noise transmitted through the floorboards will be pretty bad.
So, whats the thoughts on doing this? Do we just push up some insulation between the joists? If so, what kind of insulation is advisable? I guess I am mainly concerned about any risk associated with reducing the air flow in the spaces between the joists... is this a valid concern? Anything else to be wary of?
We'd like to do the same with the basement ceiling too and is there anything particular about doing that which we should be aware of? Perhaps more concerned there about the airflow as the joists are nearer to ground level and also don't want to reduce the ventilation of the basement as it is pretty damp down there!
Thanks for any help or advice.
Chris
Chris
